I am trying reload Media lab 2.0 on my Android tv omega 1.3 box. Would it be possible to sideload with Downloader?? Any help would be kgp54 thank you
If your box allows you to install from unknown sources then yes. The only time you cant sideload anything is on devices that have locked firmware or closed the access to sideload. If you can turn on install from unknown sources then yes you should be able too.
