Do I follow same process as the past. TP tut.recording live TV to flash. I.E. partition flash, create folder in xplore, then point to that folder in tv mate recordings. Or can I simply format my flash to internal and record to that.
I set my firestick up to record on a flash drive first following TP, How to Expand Internal Storage on Firestick & Fire TV Cube (troypoint.com)
But I then moved on to setting up a home DVR using my laptop again following TP and it works awesome. Watch any recording on any TV set up with Tivimate. How to Build a Whole-Home IPTV DVR (troypoint.com)
Hope this helps.
The absolute best way to do this is follow what @Shameful1 mentioned.
It is a great way to do recording.
Hi I don’t know if I’m in the right place here about TV mate recordings for some reason TV mate will not let me cancel my recordings and when I record a 30-minute show I’ll get 119 minutes is there any way to fix this I could use the help thank you
Hey @ denny0, sorry to get back late, but this is fo sure the place to get an answer to that. It’s the best forum I know for chord- cutters. I’ve used tivimate for longtime ,never faced that issue. But reach out to @ Miki, great source & always or almost always, has answer to help. Also, I’ve had a much smoother experience w/recording in a media player called Sparkle. It’s in the tp toolbox, check it out.
& BTW, Welcome to the tp insider community !!!
