Can i record from iptv
What app are you using for your IPTV? You certainly can in TiViMate. I wouldn’t do this, on a stick, unless I had added storage or you are using the 2nd Gen 4K Max with 16GB internal. When I recorded IPTV using TiViMate, each half hour of recording used up 1GB of space.
