I have orion free, but with using RD I also find I rarely use Orion, although I do see a number of scrapes.
That’s why I use Torrentio, free Orion is limited to 100 scrapes a day I believe. Torrentio is unlimited.
@Miki Been having issues with Stremio and " continue watching" section. The only way i can get it to function, is to start next episode of a series for a few minutes, and then exit.
If i just exit at the end of an episode, it does not appear next time i open the app.
I contacted Stremio a few weeks ago and politely raised the issue. They said they were aware of the issue. A couple of days ago I sent a request to see if there was any progress on the fix.
The reply was not helpful and rather curt.
Yep, i am aware that it is a free apk, but support is not the best
Hi. I experience occasional issues just as you. I am not going to enter into a discussion about the reasons for the problems; but I will tell you what I do that works as a workaround, which you might have discovered. If I totally exit Syncler, when I am done watching, I rarely see the issue. In other words, I don’t just stop and leave it in serch-for-sources “page.” The other work around, which always works, but is a pain in the butt, is to restart my android box. I have not been using my Fire TV for a while now. I love Syncler, so I put up wiith it… Hope this helps.
I had some troubles with Stremio yesterday (Stremio is my number one), I uninstalled it, rebooted, and reinstalled the new 1.5.9 edition. No problems, works great. When Stremio first opens and continue watching displays, long press on any program you wish to eliminate. Go to your Library and Series to begin watching and everything works perfectly, for me.
Hi. Thanks for your input. But i think we are discussing two separate apks. I was referring to Stremio and you mentioned syncler.
Love onestream , probably my favorite APK out. Love the one click. Do you know any other Apk’s with this set up?
If I remember correctly, although not specifically for movies or series, there is “sportsfire”, which, as it’s name suggests, is sports focused, but has a similar ease of use one click. Welcome to Troypoint.
Have fun and STREAM ON!
Thank you, will give it a shot
No I didn’t say that. I have KODI on steroids, Weyd and syncler+. But there are always new apk’s and I like to try new ones. Plus Syncler is lagging in many ways. Weyd is great but I like syncler+ interface. KODI is love/hate and takes too much time. But it does work better than ever. So the only one I don’t want is stremio.
OMG please close this topic!!
