Good morning Troypointers, this might sound like a silly question, but maybe some of you out there are as curious as i am. I have a Onn 4k Pro. My remote is the one with the 4 quick launch buttons at the bottom. YouTube, Netflix, Disney+, Paramount+. I don’t use any of these services. Is there a way to reassign these buttons so that if i accidentally press one of them, nothing happens? This question also applies to the big Netflix button on the bottom of my Nvidia Shield Pro remote. Thanks✌️
Button Mapper works well. Search TP and you should see some threads about it.
I used it to make my Netflix button a Mute button on my Nvidia. I would think it would work with the Onn remote as well. Just search here before you use in case there problems from others.
I’ve recently started using tvQuickActions to remap a few buttons on the Onn Pro. You can even define short press, two presses or long one. It’s working perfectly for me.
Anyone found similar solution for the mini keyboards like iPazzPort?
