Check tomorrow, something similar happened awhile back and it was a rd issue that was fixed…not to say it might not be…just hopeful.
Yes it happened to me. Do the search you’ll find it. Same show too!
You could be like me and not use a debrid service. I usually have to try 3-4 links before I find a good one in Stremio, but I also only watch 1080 resolution. Just curious why you didn’t try standard, non debrid, links when the debrid services went down? My goto now, not using debrid, is Film+ since the first link listed usually runs well with no buffering whereas like I said, I’ll have to try a few links in Stremio to get a good one. I do kind of miss RARBG (sp?) links though. .
RARBG was the best. I couldn’t get any decent streams without Rd. Especially on the last season of the show. Also if I do not use Rd if I try to fast forward or stop it becomes very unstable.
I guess I’m one of the lucky ones. Lots of sources in Torrentio, Torrentio lite, and so on. Loving eztv source. Always top quality. I do miss RARBG but the replacements have worked just fine for me. I watch Stremio every night without even one second of buffering or lag/lockup.
Well don’t get me wrong, stremio with RD been working great for me too. I was just referencing a particular show it’s last season.
I downloaded film Plus at one time, however at that time it didn’t flip my lid I may try it again thanks.
Admittedly, without a debrid service, I’ve learned to “baby” the stream. Pause usually works fine but you are flirting with disaster doing anything more complex.
I can second this experience. I haven’t used it too long but the quality has been outstanding and impressed me.
