Realdebrid enable
Does realdebrid need to be enabled in all apps or just once? Is there a central Kodi location the various apps can reference?
All apps bruv, that’s what I do.
Depends on whether you are using individual addons or Builds. For Example I use the Grindouse Builds and I only need to enable/reauthorize in Resolve URL not each of the Addons
Should be just once if you do it right. Go into Kodi settings, system settings, addons, manage dependencies (I think because I’m speaking from memory)
The current build I’m using even has a Debrid main menu choice, but enabling it there almost always requires individual enables nevertheless (Seren comes to mind.) There could be a delay between ‘system’ enable and each build app checking. I seem to always need to enable each app after a build change or even major app updates. They seem to lose the setting. Just wanted to see if I was unnecessarily enabling each app’s resolver.
Which build are you using?
Using Atomic Matrix 19 at the moment, but it doesn’t seem particularly build-sensitive. Not unexpected as the builds are basically Kodi GUIs and have the same base.
I use Builds as well and after a Build Upgrade I DO have to reauthorize RD but only in Resolve URL, not any of my Addons
Thanks for the replies. I may well have started by updating individual apps. When/if it is again necessary, I’ll try to remember to try the resolver first and verify the apps pick it up.
