Real debrid with stremio help
I am having issues with real debrid links on Stremio. I have reset and authorized several times but keep getting “failed to playback” on every single debrid link. Any help?
@c21ludecke
Welcome to our community.
Firstly, with stremio I noticed the rd links aren’t aren’t always the first option, any thing that says (RD) beside the name is a obvious rd link and to setup rd you need to configure torrentio with your rd app. Make sure your real debrid isn’t out of time.
Also are you getting that on all stremio links? Even the non rd?
Real Debrid is active. Can I setup Torrentio within Stremio for Real Dedrid?
@c21ludecke
As a newer member I really suggest looking at the website and using the search function for the best results in getting you setup
Guide which includes real debrid
Take your time with this setup. Also note stremio can be used without rd and is pretty good finding links.
Lots of addons to consider, make sure you have a vpn.
This topic was automatically closed after 6 days. New replies are no longer allowed.
