I have an Orion account set up through Stremio but somehow when I set it up I did not get Real-Debrid linked to it. I get a ton of Orion sources on Stremio none have RD. I tried to go into my Orion account numerous times to see if I could refresh RD but I can’t find the original screen for RD that popped up when I registered. Do I have to delete my account and sign up again?
If yoy linked orion to your rd in stremio orion links will show and will have RD beside them of its a orion rd link.
I linked Torrrentio to RD and I see RD by some of the links but not for Orion. When I registered for Orion there was a pop up screen for RD and I believe I linked them as I have done dozens of times with other apps. So with Kodi addons like The Crew you can refresh RD which is needed sometimes but for Orion I do not see anything to relink RD. So my question is do I need to delete my account and register again. At this point the Most of the Orion links are of no use since there is a lot of buffering.
Scroll down, orion links are at the bottom. If you have an orion and rd, you can link rd in your orion panal, that way orion finds its links plus rd and dont have to link rd to stremio.
They shouldnt biffer, that sounds like a network issue on your end maybe.
