Real-Debrid replaced by All-Debrid in Superman build?
Was trying out Superman and following along with the video instructions when I got to selecting the premium add on that was Real-Debrid it was something else. I scrolled up and down through all of the selections no Real-Debrid. I went ahead and set it up in Fen nad it worked nicely but I was really hoping i could use the global setting and not have to do it with each Add on. Anyway FYI Real-Debrid no longer an option in the build add on’s.
That issue has been addressed in this forum. I believe what was the solution was there TWO places to look for validating RD and if I remember correctly RD can be found on the 2nd list.
Anyway, do a search here and you will find the thread.
R. Debrid install. The URL list is alphabetical. Scroll down to about resolver 2 or 3.You will find real debrid in there.
Thanks, I as trying to find the thread where that was discussed to give to the op.
Now i can quit looking. lol
Thanks I found it. My mistake was I was taking the video as gospel and not scrolling up and down inside the resolvers. In the video it was at the top of universal resolver 2, now it’s the third one down. But thanks again you got me looking around. I appreciate it.
Same problem i get to real debrid
Resolver and it wont highlight
Jumps to the next one…???
