can`t add my account to cinema HD
It’s pretty easy. Not sure exactly what trouble you are having. Tell me what’s going on in more detail and I will help you.
realdebrid has it connected on there page but the apk keeps buffering and cant close so it won
t load on device
You are likely using a Firestick and I am using a Shield. I can’t duplicate the problem. Possibly someone can help out?
found the problem was an app installed to watch multi channels on tivimate
did refresh with shield and alls well
Can you walk us through this solution?
Im having the same problem on firestick
RD is down, they’re working on it.
