Is real debrid down or just not working as before
I am using Real-Debrid as I type this. Having no problems at all. Most likely it is problem with Cinema, Cyberflix, etc. Or your subscription expires. Otherwise try to re-authorize.
Thank you for info. I will try again as I was not able to log in to real-debrid web page earlier
