Chave real debrid connected to teatv however links showing atent color coded or showing rd on the links. I tried putting only real debrid links to connect to and it shows numerous links but they arent identifying as rd links. Any suggestions. They are playing well.
I’m using a modded version of TeaTV and also have RD authorized and found the same thing. I’m sorry but I have been unable to find a reason for this or a solution. TeaTV is only my backup as I use Stremio all the time, so I’m not really concerned. I just wanted you to know you aren’t alone.
https://www.teatv.net/real-debrid-not-working-how-to-fix-do-i-need-vpn-with-real-debrid-133278/
I notice the same but after clicking on a TV eposide the RD links were not there but then I backed out and tried again,…then waited about 20 seconds and they were there.
