“So if you decide to use real-debrid with an add-on such as the Crew, turn your VPN off when authorizing and linking it to the Crew add on, then reconnect to your VPN before streaming.”
Why would i need to turn off my vpn when authorizing? Just wondering.
Matrix
April 11, 2022, 10:08am
2
@Menuflynn
Well those are the normal procedure otherwise you will have difficulty not connecting to authorize RD.
I’m my case in older Kodi version 18/19 I couldn’t authorize RD with VPN on.
In later kodi version 19 and up I authorize RD with VPN on.
So it is up to you to decide to authorize RD with or without VPN on.
But now you know when try to authorize RD.
Also consider to restart kodi after authorisation.
Miki
April 11, 2022, 12:41pm
3
When I experimented with The Crew ad on I authorized and reauthorized with VPN active.
Kodi Matrix 19.4 on Firestick 4K Max.
@Menuflynn
You dont have to worry about turnning off your vpn unless its on the non compatible list
Ok. Ive never had to turn off my vpn. I was just making sure there wasn’t sumn i was missing.
All good, enjoy rd bliss.
