I hope this is the correct place to post this and get an answer from somebody. My issue: when I select a real debrid link for a tv show, it will go to an entirely different show. And iti’s not just one provider, it’s several. Has anyone else had this problem? And I can’t find a place on real debrid to get an answer. Help.
I use Real-Debrid and have been using it with Kodi for over three years. I use it with The Crew, The Promise, and Nightwing. Before that it was Oath and Marauder along with The Crew. I have never had that problem even once.
It sounds like your real debrid subscription time is up or something, because i rarely ever get a wrong link with it.
Make sure your real debrid is up-to-date. Re authorize your account Delete your devices in real debrid and re add them Make sure they are added in real debrid.
OK, I’m not very tech savvy, so thank you so much for your help. I know it hasn’t expired. I just renewed it just a couple of months ago for 6 months, so that isn’t the problem, But I will reauthorize it and see if that helps Thanks again.
I just now tried The Crew and a few episodes of some of the shows I watch. I had no problem getting links or correct episodes for the shows I wanted. When you reauthorized Real-Debrid did you turn off your VPN? I can think of no other reason it would not bring in correct links or any links at all.
This happens all the time, not on the “ most popular episodes “, but many shows that involve true crime or crime investigation there’s a good chance you’re going to get “evil lives here”, for example
Also, sometimes you might get “no stream available “ while trying a show in “tv calendar “, but if you back out and do a search for that show, it’s quite likely to work
I’ve been having similiar issues to the above. The incorrect episode is being returned with True Crime series - Very Bad People, Time To Kill etc. It’s happened with Crew and Seren but when I use Cinema it never happens. I’m not exactly sure how the process works but I was assuming it was mislabelling by the seeders. I thought I’d post in case this is the start of some more serious issue.
That’s the third party after using that’s what it’s searching for nothing to do with real debrid try using Cody it never really doesn’t ever give you the wrong show happens on film plus all the time I hope that answers your question
