when trying to connect to realdebrid with the code provided, after going to the connect your device, at realdebrid and entering the provided code within the alloted time frame i get the error message invalid device code, it may have expire
A few suggestions, make sure your Real-debrid sub didn’t expire. Are you using a Real-debrid friendly VPN, are you using a VPN at all?
Be careful with certain characters when punching in your device authorization code. Letters and numbers can be misinterpreted easily, like 0-O, 1-I, etc.
The code does expire if you wait too long, but it sounds like you’re already aware.
Also make sure you’re authorizing the correct “debrid” service (e.g. Real Debrid vs All Debrid).
no vpn yet will wait until realdebrid is installed
What add-on or build are you trying to authorize?
Kodi and just onstalled crew
