OK, I’ve followed the installation instructions on Troypoint about installing Stremio and Torrentio a dozen times. On a firestick, everything seems to be working as it should without Real Debrid. When I try to install Real Debrid, I follow the instructions word-for-word. After trying to install the API token at least a dozen times (triple and quadruple checked the code and the input) it still gives a “Real Debrid error - invalid token”. I’ve gone back to the Real Debrid site as many times and checked the token and its correct. Real Debrid account is good till August. I’m at a loss!
Just thought id mention that Film + is up and running good with RD. Just did an update and it wanted to install a new player called mate?.. but other than that looking good.
You can use stremio without real debrid it pulls the same torrents because of community addons that pull from torrent sites.
But there is a difference. You will not get rd https encryption or server sided backup. You will need a vpn on always and there may be a chance your options might be less as it’s not a mega hoster. So far I haven’t run into to many issues regarding that. But if you can’t get rd hooked in then here is the addons you want. (This is best for shows and TV go through the community addons as there is alot to offer)
Cinemeta
Youtube
Watching
Public domain movies
Open subtitles
Local files
Torrentio
The pirate Bay
123 movies
Juan Carlos
Orion
The movie data base
Tmdb database
Cinemeta extend
The pirate Bay catalog
All those are available in the stremio community addon section and will get you what you need.
I may actually setup a topic just for stremio addons. The guide from troypoint works well.
I’d been using film plus too until the last update and they’ve gone he stupid mandatory player route with boat-loads of ads. What’s with these apps doing this (BeeTV, TeaTV, filmplus)?
