RBC rolling watermark
Gentlemen,
When using OnStream or FLIXVision with Premiumize I keep getting the Rolling RBC watermark running across the screen. It’s very annoying. Anyone else encounter this? Is there a way to eliminate it. Thanks and I hope you all have a happy Easter.
I had the same issue watching a movie that was recorded via CAM in the theatre. It was a movie in my provider’s VOD section.
If you are watching something that only has CAM streams, you are going to get these annoying ads. You might have to wait for a movie (usually newer ones) to have 4k, 1080, 720 streams - they will not have these ads.
@ websurferdude Thanks for your response. Happy Easter.
