Well there is my apps but didn’t you not clearly see that nothing opened at all and that you couldn’t see what apps you was scrolling on
Click an app and it opens. Use the remote to navigate over an icon to focus on it and click your ok button on the remote
Nothing opens at all and that video proves I am unable to open anything in Wolf Launcher
I just saw Peacock and I can’t tell if it’s actually installed. Did you try the launcher settings?
I think you will need to go back to my original comment about uninstalling and reinstalling following Troy’s video I posted. If none of your apps will open then you may have a corrupt download/install.
I deleted the Wolf Launcher and Launcher Manager and then reinstalled both and changed something in the Launcher Manager settings and now I can open apps
Perfect. Congratulations. Can you please click the checkmark at the bottom of my post suggesting the uninstall/reinstall as a solution thank you.
