I have the new Firestick 4k max; however, I do not have screen saver under display. I contacted Amazon, they had me do a factory reset to no avail. They sent me a new 4k max and this one also did not have screen saver under display. Does anyone know have to correct this issue? Thank you
Under Display and Sounds, click the Ambient Experience. It’s now the screen saver settings under Preferences.
Wow, thank you for responding.
Can’t find screen saver settings on new Firestick 4K Max? I want to turn it off, it is set on factory default five minutes.
Thanks for the response. Did what you suggested, but it still turns off after five minutes.
Have you checked your sleep mode in settings?
There isn’t a screensaver any more.
What Is the Fire TV Ambient Experience? - Amazon Customer Service.
Thanks, put it on the 15 minute hold. Was wanting to put it on never but the new fire sticks only go to 15 minutes. Thanks for all the help.
Are you sure you have the latest updates as they added “never” as an option in an update.
https://www.reddit.com/r/firetvstick/comments/174ejzj/cant_delay_sleep_timer_on_new_4k_max_gen_2/
Try this…sleep mode
How to set custom Sleep or Screensaver times on the Amazon Fire TV or Stick without root | AFTVnews
Also, read in the comments about using the AppStarter to fix your issue.
In X-plore AOK go to system apps,scroll down to screensaver and open it. you can turn it off there
Hi! I have the firestick 4k max 2nd gen. I can’t find Screensaver in Displays and sound. Im trying to disable the Screensaver. Any suggestions, please.
