Currently I have another year of NordVpn, is it ok to use nord as my vpn, then later when the subscrip. runs out, switch over to ipvanish?
Stick with Nord. Imho it outperforms IPVanish.
Hello @cox3523 yes, that is perfectly fine. I always say that comparing VPNs is like arguing between Windows vs Mac or Android vs iOS. Depending on your location and network, some VPNs perform better than others. You can try IPVanish risk-free for 30 days and if it doesn’t work for you, stick with Nord. I get much better download speeds with IPVanish than Nord. I am currently getting over 150 Mbps on my Fire TV Stick 4K Max with IPVanish. Others won’t have the same success due to their location. Again, there are a lot of factors at play here when it comes to these services.
