Last evening Seren was not working, so I went to Crew to watch a program. Worked great for half the time, then a small circle appeared and counted down. The countdown only lasted a few seconds. This happened about 5 times until the program ended. I have RD installed and believe it is working. Thanks in advance for suggestions.
RD was down last night, most likely why you were having issues.
I had a similar problem last night June 17th. Using CREW, a program was nearing the end and the small circle appeared and the count down lasted almost 2 minutes. The program started up and finished. All my options to watch show RD.
