This is my best HDMI cord.
Highwings 8K 10K 4K HDMI Cable 48Gbps 6.6FT/2M, Certified Ultra High Speed HDMI Cable Braided Cord-4K@120Hz 8K@60Hz, DTS:X, HDCP 2.2 & 2.3, HDR 10 Compatible with Roku TV/PS5/HDTV/Blu-ray
Brand Highwings
Connector Type HDMI
Cable Type HDMI
Compatible Devices 4K & 8K Blu-Ray Player, Monitor, Television, Sky Q, PlayStation5
Special Feature Braided, High Speed
About this item
Top Technology----8K@60HZ: This 8K Ultra High Speed HDMI Cable uses the most cutting-edge technology, is compatible with 8K@60HZ and 4K@120HZ, clearly displays every particle, and accurately processes every signal source.
Upgrade Revolution: Highwings Ultra High Speed HDMI Cable supports 48Gbps (6GB/s) which can will no longer be stuck or dropped frames when watching video. It is also backward compatible with HDMI 2.0b/2.0a/1.4/1.3/1.2/1.1 versions.
For Game Enthusiasts: This 8K Ultra High Speed HDMI Cable can achieve a super smooth picture of 4K@120HZ. Its latest game mode supports variable refresh rate, maximizes the value of the graphics card and CPU to obtain a smoother and more detailed picture.
Reinforced High-quality Materials: This 8K HDMI Cord uses Highwings’ most popular classic style. The tail’s anti-bending design has been upgraded to make it more durable. The military grade tensile nylon material also greatly extends its life.
The Ultimate Perfectionist: Highwings every parts of the cable has been put through rigorous the performance tests in the laboratory. After we’ve combined every flawless part into a perfect 8K cable and it can be presented to you. If your devices want to achieve the 8K HD display, those should support the 8K firstly. If your devices are still not sure to support 8k, pls ask your device retailer or our customer service for help.
