Problem with Source Select in Umbrella
I’ve been trying to get Umbrella to work so I can continue to to use RD, as it seems to find more source options than Premiumize.
I am running 21.1 Kodi on a Shield Pro.
I also run Seren with Premiumize as a back up alternative. Seren generally works fine, but sometimes fails to find the content I’m looking for.
I have Umbrella set to Source Select, and I get the full list of sources from RD. Scraper timeout is set at 90 sec.
The problem is, that when I select a source, it does not remain on that source for more than 10 seconds, and automatically switches to the next source for 10 sec, then the next source for 10 sec, etc.
10 seconds is not long enough to complete the connection, so it runs through all the sources, 10 seconds at a time, and then says no available sources.
This was happening on both movies and shows and I had been unable to watch any movies or shows on Umbrella.
Under “Source Options” I turned on “Only Try One Source”. This has enabled me to watch most TV shows on Umbrella but did not make any difference to Movies.
Now in TV Shows, “Try one source” overrides Source Select, and does not provide me with a list of sources to choose from. Instead it appears to just take the first source and can take up to 2 minutes to get a connection. This works fine as long as the first source is in English. But if it’s in Russian or Italian, and I can’t change language in settings, I’m out of luck. I don’t get to choose another source.
And I’m still unable to watch any movies in Umbrella. It still lists all sources but skips every 10 sec.
Everything else is, I believe, at original settings. I’ve reinstalled Umbrella twice to no avail.
This seems to be a unique problem. Any advice would be most appreciated.
Thanks
Don
A post was merged into an existing topic: How to Install Umbrella Kodi Addon on Firestick & Android TV
