is this program down today/tonite labor day
No mine is working perfectly . What is yours doing
opens up but shows will not load
rebooted real derid
Don’t understand what you mean by show’s won’t load. Do you mean it’s not returning any links
correct none will load up
Did you check to make sure your Rd is current and check to make sure your data in your settings didn’t get wiped
been working great links give choices wuthun 10 seconds
but none tonite
need help i’m 73 what is rd?
Real debrid is it up to date not expired
sorry of course
and the settings is that express?
your right it did expire-never gave me a notice will reup
thanks
Yes and if it was working you should instead your Rd info
Here for future reference.
No it won’t give you notice you have to keep track yourself. Glad you got it figured. If you can click on solved below so @TP-Dracoo can close this out . Glad I could help
Was looking for that in tag’s to give to him and didn’t see it would be good to add that if not there already
sorry cant find closed
Should be a spot to check solved
No prob he knows
Its a saved msg i have in my arsenal of pre written stuff for these situations. Canned msg.
Im very happy you got this working.
many thanks guys will stay ontop of it
