Problem with Downloader and Troypoint Toolbox
I just checked mine seems to be working okay, check your settings for the buttons on the remote of your Shield pro.
Is your downloader updated? On my Shield Pro it’s now 1.5.0-ForGoogleAndroidDevices
Just used Troypoint-toolbox with downloader on my Nvidia Shield pro and works great The mouse cursor is a little fast, but we’ll let you stop on of What you want to download
I dont see how to update the Downloader app. Where do I go to update Downloader?
Downloader is back in the Google Play Store. It should update from there.
For either the Amazon app store or Google Play
https://www.aftvnews.com/downloader/
I have the new Onn 4K and cannot get the toggle to work in Troy’s toolbox. It jumps all over the place. However it works well in other apps. I have uninstalled and reinstalled with no results. I looked thru the topics and couldn’t find a good solution. Thanks
Hello @Remy this usually has to do with setting all of the animation scale settings to zero in developer options. Take a look in there and make sure the first two are set to 0 and the third one is set to .5. If it still doesn’t work, try setting all of them to .5.
OK, thanks.
Set them all to .5 and it works much better Thanks for the info
