Since BeeTV had its latest update, it no longer works. Not sure if anyone else has had the same problem.
If you open it, you can load it and get the list of TV/Movies and it even lets you go to your favourites, but if you click on any of them, it throws you back out and onto the main page.
Would be interested to see if anyone else has the same problem.
I’ve had problems as well. It won’t update. It also only allows me the Titon video player and nothing else. Asks me to install, then nothing works. I’m going to switch back to Cinema unless any other ideas?
I’ll download and install BeeTV and run it through it’s paces and see what it spits out. Ok done, installed and using MX Player Pro. Runs flawlessly. Sorry, forgot to mention, this is on a 4K Max. Also authorized RD. Oh and there’s more. I saw I was on 3.1.3 so updated to 3.2.0. That also worked perfectly.
Yes, the 3.2.0 update this week (official version on Firestick 4k) has trashed BeeTV. Ads, and slow as molasses. I’ve been able to install VLC as the external player using the usual method but that hasn’t helped the speed issue or ads.
Odd. I only got one ad when closing a movie. As I have a mini keyboard hooked into my 4K hub it was easy enough to close. That was on the 3.1.3, no ads yet on the 3.2.0 You are right, it’s pretty slow loading and I don’t see anywhere that any RD links are displayed, but I may just not know how to recognize an RD link in their app.
The thing is, on my Max I installed and ran the previous version, I then updated to the latest version. I used the “official” version. Everything works. External player Sources RD integration Media
