Can anyone give me a solution to this problem? “ Parse Error There is a problem parsing this package.” I keep receiving this error when I try to install files using Downloader.
Go into your device settings, then go to apps and select downloader. Clear cache and data and see if that clears up the problem. If not, delete and reinstall the app. Hope this helps.
After further research, I actually had to use a program called APK Editor Pro and make some slight modifications to APK. That seemed to work.
Thanks
What mods did you make to the downloader app.thanks
That’s great thanks it worked for me
