Do all IPTV channel providers work with IPTV pre-installed on Formuler Z8 pro
There isn’t a “one solution fits all” app on any device that will permit integration with every IPTV supplier. Some have their own apps coded specifically for their IPTV. Others provide xtream codes or m3u and epg to enter into apps like TiViMate. Now TiViMate with the premium sub, you can enter multiple suppliers, but not all.
If you find a formuler pre-installed with iptv I would think thats a 3rd party seller and not formuler. As far as iptv on formuler I would think most should work set up correctly.
I’m using a formula Z8 with three different IPTV provider’s all three are set up using Xtreme codes and work fine. For the record I did trial another provider using M3U and again that worked fine as well. Maybe you can try your provider using M3U, also consider downloading IPTV Smarters to the Z8 and if your provider works using IPTV Smarters within the Z8 then there maybe an issue between your provider and Mytvonline2
