POVico build using kodi fork 20.1 keep crashing on startup.
What device are you using?
Try going back to kodi 19.5. I had same issue on 20.
After installing the 19.5 fork, when following the POVico installation instructions the POVico wizzard is no longer an option. It installs a real debrid manager instead
Im not sure what is happening with the 709 repo, as the wizard doesn’t work or the build menu.
Sorry i was gonna tell you before you installed 19.5.
Anyone know what is up with 709?
OK. I reinstalled POVico build on 20.1 fork. It still kicks you off kodi if you let it boot up normally. The work around is IMMEDIATELY click on the search icon for movies to INTERRUPT THE STARTUP PROCESS. Then simply backout to the home screen and you’re good to go. It won’t kick you off. Hope this helps
Wizard is only for kodi 20 now, explains why it wasnt working on kodi 19.5. Just trying out arctic rain build.
Any stability issues with Artic build?
Yes, keeps freezing and kicking out to home screen this is on nvidia shield pro. The shield doesn’t have enough ram to run builds like that. Try xlite build runs well even on firstick 4k max.
Been using the Grindhouse Builds for about 4 years now. Dev is on top of things and they run smoothly
