Can anyone tell me what video had the pluto install to iptv
Thanks. I’d still like to find the video that I used originally.
Infortunately it appears none of the pluto m3u or m3u8 playlists are working. It appears you now need to install their app.
You can try one of these but I had no luck
https://i.mjh.nz/PlutoTV/
Just tried my PlutoTV m3u8 & its working fine
Ya I got something going wrong. What’s the m3u8 you have?
The m3u8 you posted above about an hour ago…
how odd. Not working in my tivimate
Weird…you have any other players you can put it in? Don’t know how it could be a regional thing
Never had any issues with tivi before. It loaded and epg propagated. Just nothing played. Going back at it in 10
Hmmm. I’m getting an HttpDataSource$HttpDataSourceException
and nothing plays. So that’s the provider. Have to try a new VPN location.
Hmmm…that’s a head scratcher…how about all your other m3u’s? Guess it could be some sort of snafu between your isp & their servers…if so, hopefully just temporary.
Got it. For some reason it was blocking my Dallas VPN. I had yo switch to New York.
Must just be a particular server in Dallas, as that’s where I always connect. I’m on 37.19.200.106 if you want to bounce around on them & see if any others work or not.
tx as always pan. Doing that now.
It’s always something different…& interesting…gotta love this hobby
Roger that…the m3u8 must have epg embedded, as mine is fully populated. Got it put in if needed tho.
m3u8 indicates an embedded epg xml . I love m3u8 because of the ease of the epg auto loading.
I posted it because the coder post the xml files after every m3u8, not sure why but guessing country or something???
