Hi guys, I would like to install Pluto TV on my firestick, but the country I live in doesn’t have Pluto TV so it is not in the appstore…
I guess I need an APK of Pluto Tv and install it through downloader but I cannot find one that work, do you know where to download it or how to find Pluto TV app, I’ve tried to use a VPN to change the App Store region but it stays in the country I live in.
In my opinion the lifetime sub for TiViMate is the best deal on earth. TiViMate is great for IPTV. It was $25 U.S. I believe. Very configurable and adding playlists is a breeze.
I see! Okay I think an option could be to get the App via Unlinked as I’m sure Pluto TV is available in the D9BCD4D8 library.
Just checked and Pluto TV is indeed there for you to download. If you haven’t got Unlinked, then use the search option and I’m sure you will get a link/tutorial to instal it Then add a new library and enter D9BCD4D8 and within the Live TV / Sports you will see Pluto TV.
I watched the video last night explaining how to install IPTV Smarters Pro with the pluto link. I went to rewatch the video right now and I cannot find it. I need to find the EPG Source for Pluto TV that Troy was showing in the video. Do you know how I can find the video please???
If you have an android tv box you can download pluto, zumo etc…then get the app live channels and it will(with setup) pull in all the channels from pluto, zumo etc(includind tv tuner if you have one) and combine them all together in the live channel app. From there you can customize it.
it’s an m3u8 so has the epg already integrated into it. You don’t have to enter an EPG url as it will automatically do that during the playlist install
Yes I can give you the url for the xml epg but the 8 added to the end of m3u denotes an integrated epg which is one less thing you have to enter. https://i.mjh.nz/PlutoTV/all.xml
or https://i.mjh.nz/PlutoTV/us.xml.gz
the gz on the end denotes a compressed file, but those are 2 of the pluto EPGs and you can use them in any playlist for added channel EPGs.
