Please keep in mind that if you are having guide issues that there isnt anything troypoint can do about it. There is only a few small things which would be adjusting your buffer size on tivimate if you use it and making sure your internet speed is above 30 down. After that you can try to reset it otherwise you will need to speak to your proivder. These iptv guys will always struggle with guides and buffering especially high load times.
or hope that @Miki steps in and helps! ![]()
Lol, he will just say the same thing. Not much that guy can do from his lazy boy down at the beach. Lucky…
I certainly can do more, but @TP-Dracoo’s ban hammer hurts.
You mean the one used on Paul Pelosi?
Really not much you can do with server sided implications… banned.
Yep. Very good point reminding folks that guide issues are on the server side and not the player almost every time
