hi i am in the uk and i am using peacock US when watching anything it is zoomed in so you can only see part of what i am watching can anyone help with this thanks
Welcome , can you find a square or anything in the corner of the screen to click on? if you can hook a usb keyboard to it via a otg cable or hub that might give you the f11 option like on a pc. Mouse Toggle program may give you the ability to find it. Hope this gives you some ideas. ![]()
thanks for the reply i have switched regions on the box and downloaded it from the app store
What device are you on? Is this on the Peacock app?
i am using firebox with peacock app
Firebox? Do you mean the Cube?
If this is a FireTV OS device you need to go into the video settings and set it to 1080p. If I remember correctly peacock is only 1080p max.
