I’ have successfully paired my Bose Sound Link Revolve Bluetooth Speaker to my ONN box. But I
cannot get any sound from it, I’ve made sure the volume is way up but still no sound…
Any advice?
Thx
Any advice?
Thx
What app/apk are you using that won’t play the sound through your Bluetooth speaker?
Did you check settings to see if Pass thru audio was enabled? Welcome
I fixes the issue by rebooting my ONN box. Thanks for your response…
I fixed the issue by rebooting my ONN box. Thanks for your response…
