Just wondering if anyone knows optimal device settings for tv boxes? And/or if there is a good places nfornthe various meaning ls of the terms used in devices? ie - tunneled? On/off? etc…
This is the sort of thing you need to search for and the site search
can help find threads/Topics with some answers.
Video terms and acronyms.
As far as optimal device settings I am afraid there are way to many variables for anyone to give precise instructions. Troy has many videos that you can watch and learn from.
The best resource I was able to follow was by using Copilot AI provided through Microsoft Edge. Needed to optimize the coordinating settings between ONN 4K Pro, DENON 7.2 receiver, and LG 75 OLED. While it took approximately 5-6 hours, the end result was a consistent operating system.
Copilot explains the necessity/reasons for changing each connecting element’s system options, and step-by-step directions to reach your desired optimal complete coordinated surround system that you can copy and print a direction manual for possible future need.
If you don’t understand the terminology or the system set-up steps seem to be confusing, you can ask Copilot to provide further simplified explanations until their advisory makes sense and all clicks in. So, you can be educated and provided a comprehensive simplified manual to print out (you’ll need to copy and paste onto pdf pages - ADOBE) for each element of your system and have full user-friendly system adjustment coordination references, in layman’s terms, when your set-up is finalized and running. It works, good luck.
