Opensubtitles won't verify. Newbie
I get the following message from kodi after beginning streaming a movie using Crew and asking for subtitles:
Error searching for subtitles
Your open subtitles.org username or password is empty or not
valid.
OK. I have run through the checklist twice and the Kodi opensubtitles area reports “enabled”. Please suggest what I am doing wrong. Checked password and is good on open subtitles website and on initial entry during checklist.
Should I reload kodi or reload Crew or use MX player?? Using Firestick4K.
Hi @Linusbear
You can try to enable and designate mx or vlc player.
Sometimes, force close and clear cache helps.
Others will have suggestions too, which are worthy of trying too.
I had problems with OpenSubtitles, too. I now use Subscene and Addic7ed.
A4k subtitles is the best!
