I recently downloaded the new Superman build for Kodi. Does this come with subtitle app, if not how do I add open subtitles app on this build. The normal kodi screen doesn’t come up to add them. Thanks
Had the same problem and fixed it!
Go to Add-ons - go 1 down to click “Add-On Browser” - then click Install from Repository - scroll to Kodi Add-on Repository and click - Scroll down to Subtitles - I enabled both opensubtitles.org and opensubtitles.com.
IMPORTANT - after enabling them - click on each - click Configure and add your user name and password!
