Open Subtitles needs to toggle on
Within the last few days Open Subtitles gives me a message that subtitles can’t be downloaded because my password or email is incorrect. I discovered that the open subtitles toggle is off. By simply turning it on they load as before. Is anyone else experiencing this issue? It’s an easy fix but annoying after years of working seamlessly. Any help for a permanent fix, if there is one, would be appreciated! Thank you.
Hi All, I have been using film plus with no problem at I tried different movie and tv shows all today I noticed that when I decided to watch a movie with subtitle it didn’t work I tried some other movie and tv shows it did not work the subtitle gets populated but it won’t open and work what should I do to fix that? Thanks
