onstream site is down. is there a mirror or another way to get it?
yes use the unlinked app and code FIRESTICK its in there
It’s not down for me. Give it another try. This is the official site
https://onstream.so/
that works. thank you! i had always used onstream.to
I’ve been using it all morning on my Shield Pro and everything seems hunky dory to me.
I have a few friends and family that use onstream. They have the ONN boxes. Some pro and some regular ones. About half of them are getting the can’t load content message when it starts up. Mine is working fine. On the boxes that are giving that error, other apps like tubi work just fine. Anybody else having this issue? Or suggestions for a fix? They are all running the latest version of the software
yes all working fine here.maybe check if vpn is stopping it or delete and reinstall @Tech2 has published link here
Tried installing Onstream through Troy’s toolbox and got an error message. Are there other install options for Onstream?
Won’t do any good site is down have to wait and see
