Onstream is down
Onstream is down. It indicates cannot load content. Anybody else got issues, does anybody else use it?
all working fine here
I was not able to use it either last night. It kept telling me to update it. Then when I did it would not work. Made the mistake of uninstalling it and then trying to reinstall and then it would not work at all. I am not sure what the official download actually is for a Firestick.
Not working for me either last night. Incomplete searches and stuff found wouldn’t play. Left it for today. Was also having issues with Real Debrid at the same time API Key was throwing some weird messages, so I turned to other sources and some of them were bad. Had to switch VPN server location to watch anything. Lots of buffering and freezing.
hi onstream has its own website just google it and download
Hello, thanks just went in and downloaded it again and it is working for the moment.
Add .so to the end of the word onstream for the official download site. I would not recommend downloading from any of the other unofficial clone sites that have popped up.
Onstream started working for me again. To update on stream you have to uninstall your app and reinstall a new one. I lost my log on and I’ve been using Google to log on and I still haven’t figured out how they Google does it because I’m logged off on google.
Your logons are kept in your google account and used when you invoke access by using the Google logon option. If you go into your google account and look under security you can find the password manager and see all your logons and once you use your password when prompted for your saved passwords they will also show. This is dependent on what options you chose and if you allowed the “save password” option.
yes definately you must delete old version or it will never load
Took 2 tries and it installed. Performed a search and found what I want but won’t play. Took over 1 minute to load and start for a latest movie pic.
hi Miki what are you trying to watch ile check it on mine
I did a search for “Oceans”. One took over a minute then gave a “provided by Microsoft” or similar message but then continued buffering and didn’t start. Still setting up the QN65S95C Samsung and Q990C Soundbar and this these ocean movies provide a great test for colour and motion.
just tried on mine went on ok maybe you have something blocking it ps seasick now
I’ll try a different VPN server. This is on the Shield Pro so no idea what may be the issue.
on stick here so maybe vpn need swapping around
Real slow load Switched servers and Country. Speed tested out at 179Mbps down. Sponsored by Microsoft came up and now playing just fine. Server change did it from Chicago to Toronto.
glad its working now its a good app
Yes it is. that and sportsfire are my go to backups. Have a good day @pirate77 and thanks for your help and suggestions.
Miki, I did that I checked in the password manager you indicated and it doesn’t show anything about on-stream it just shows the logons never to save a password on. I do have saved passwords on and maybe that’s what’s allowing it to log on because it could be at one time I did a lot to log on to onstream because I didn’t deem it a threat. I’m kind of glad I did because the password recover onstream doesn’t work.
