OnStream Choppy Performance?
Anyone else experiencing issues with OnStream? 10 seconds, stop, 10 seconds go?
I gave up on onstream. At first it worked very well and I was getting the feeds and good picture actually excellent picture. lately feeds haven’t been that good and then get a lot of buffering or just no connections. I went back with stremio and integrated with Rd. But funny thing on one show , I couldn’t get any good feeds from RD so actually had to go back to my IPTV service and I got good feeds from them.
Not had any problems so far
No problems
Like @AJS1 I to noticed degrading performance in OnStream and have since deleted it. Same for other similar apps and no longer have a backup for Stremio.
hi @Miki its working fine in uk
I’m going to change my VPN next time I surfshark goes crazy on me I’ll change it to the UK and see if I can get on stream then.
I try the UK, no difference. But also I just realized that I can switch vpn servers without turning off my kill switch I didn’t know that.
I have noticed the buffering with the Onstream app using the ONN box. If I leave the box plugged in for 2 or more days is when I notice the buffering. When the buffering starts I unplugged the ONN box for about 20 minutes and everything works great. So I now just unplug the box when I am done the for time being and no more buffering.
SurfShark does not support onstream, cinema and many others. You can program settings to invoke SurfShark on various apps but that does not mean they’ve done testing. I booted SurfShark a long time ago. I feel it is misleading to be allowed to make a setting that says to invoke SurfShark when SurfShark does NOT protect you when using an app or app(s).
Darkeyes
Ahhh. Ok. I thought I was going nuts—this seems to be how it works for FS also. I wasn’t sure if it was a streaming issue / app issue. The buffering technology is lengthy and requires time. Got it. Thank you.
