Hello
Just got the Onn tv box. Can you sideload it like the fire stick? Trying to find a tutorial or something to set it up!
Thanks
Hello
Thanks
Load it like any other android device, we have guides on here. Do a search. Look at the apps to install and follow the troypoint guide as they are labeled android/firestick.
Do you have the newest version from Wallmart?
No not yet I don’t think it’s out yet
The good thing is that most have had great luck with these inexpensive boxes. You should find everything you need from the TP tutes to get started and more. Good luck. Personally, I had better speeds and performance from the Walmart boxes (no bloatware too) than the FSs. But some will disagree.
