ONN Google tv box how to control avr volume with onn remote?
How can I get back to setup screen where I can pair the onn remote to Denon avr?
The gear icon
Thank you, but the gear/settings icon does not point to anything controlling the audio output device. Did factory reset and went through all 10 codes for a Denon avr, and none worked. SOL, I guess.
Doesn’t the Onn have a Remote & accessories section under settings? I assume your Denon is a blue tooth accessory so there should be an Add Bluetooth accessories in the Remote settings.
Yes it does have a Remote and accessories section Miki you are correct. He should be able to pair it there.
I removed all pairs to devices other than than my TV. I would somewhat control my Audio system. Yamaha but started making changes that it should not have. I had to un pair it.
You are correct about the Remote and Accessories section. (BTW the onn box is connected directly into the Denon avr). Went through the Denon volume codes, but “It looks like the Google tv remote can’t control the volume on this device.” Yes I was able to pair the onn box with the Denon via Bluetooth. The onn remote volume toggle showed volume up and down on a slide bar on the screen, but no corresponding volume increase or decrease on the avr. I think I’m just expecting too much from this $20 device. Thanks everybody.
