Onn box troubleshooting
Just tried setting up our ONN box. Can’t seem to get film+ or BEE movies to start playing. I loaded the recommended players but nothing still. Any help appreciated.
Delores
So they are finding sources just not playing those sources?
I have three Fire Stick 4K Max and new Onn 4k Pro box. All Fire Sticks play Real Debrid links with BeeTv and FilmPlus. I do not get Real Debrid links for these two apk’s from Onn 4k Pro.
I deleted and reinstalled and also re-authorized Real Debrid, still no links. Cinema and CyberFlix work fine in Onn 4k Pro.
Would permissions have anything to do with it?
I’ve exhausted just about all possible options.
We live in a rural area where we don’t have strong internet but all the other apps, such as Pluto, live tv and such work fine!
Anymore ideas….,
Go into settings and then apps. Look for BeeTV and FilmPlus. Scroll down and you should see permissions, you can allow either media or all.
I didn’t think permissions would have anything to do for scraping or downloading feeds. I would think it would just be to the app. But there’s a difference between different apps and how many feed you’ll get also. On Kodi I used to get over 50 to 60 or 100 feed, on stremio, only get maybe 10 to 15 if that.
Boy I’m really hating Google text!
With Fire Stick 4K Max I can get hundreds of links in BeeTV using Real Debrid. For some reason I can’t get any RD links using ONN 4k Pro. Same issue with FilmPlus.
This is showing solved but it’s not.
So let me tell the basics and y’all see if it’s my internet.
Most all apps including Netflix come right on. No trouble. But bee tv and film+ drop links but does not connect to the link. I have waited a while but link never hooks up.
We are out in n the woods. T-Mobile internet was only option other than starlink. On the router I only have 3 bars. Could that be the reason?
Thanks
Are you using a VPN? Are you using Real Debrid?
No no vpn
Using Real Debrid or just hoping the free links will populate?
