Onn box-movies not playing on apk's
In both film+ and Bee tv, I can
not get movies to play.
RD is loaded on both and I get plenty of choices.
I hit the play and nothing happens.
I have tried with the vpn on and off.
Kodi is working fine.
How about downloading Film+ as a standalone apk and try running it without using Kodi. This way you might be able to discern whether the issue is the apk or Kodi.
…jus thinkin out loud.
thanks. I did that but still not working.
Try using an external player such as VLC or MX Pro.
I’m getting this on Stremio with Onn and a Mecool box too.
I don’t think it’s the player that’s the problem, or Real Debrid, or a VPN, I’m really at a loss🤷🏼
Go into to your RD account and make sure your sub didn’t expire. The front dashboard will tell you how many days left you have on your current sub plan.
As @Powerfader suggested, using a different player (you may have to install the external player first if you haven’t already) other than the native player.
It’s definitely not RD or the player on my devices as I’ve tried with and without and with various external players, which all work on other APKs on the same box.
my R-D is ok. Will now delete the app and reinstall.
Will also try with external player
I’ve deleted both film + and Bee tv on the ONN box. Then added another APK ( cyber fix) and everything is back to normal.
How did you delete an app?
If you are asking how to delete an App on the Onn…
Go to Settings. Select Apps. Over to the right you should see a list of your installed apps. Go to the app you want deleted. Select uninstall.
There are also system apps that you cant uninstall but you may be able to disable them.
