ONN 4k Pro wants to install to flash drive after it has been ejected
Lightning hit took out the router, firestick, a TV, etc. I purchased an ONN 4k Pro.
Got it up and running, then thought about the ONN booting problem with flash drive. My wife wouldn’t be able to do it,. Transferred the apps to internal and ejected, and removed the flash drive.
Any install tries to go to external drive. “Force install to external is turned off”.
I’ve rebooted multiple times, turned USB on and off,. I can’t install Analiti! I have to delete apps that are on internal. I don’t get it.
Also, I found that ONN cannot control power for both Insignia TV and ONN sound bar, its one or the other. Tried to remove the ONN, so it would power the TV, and it hangs! Maybe I have a bad remote on top of the other problems. I’ve been badmouithing Amazon, but I sure miss the firstick 4K right now!
2 posts were merged into an existing topic: Walmart Onn 4K Pro Review & Guides
