I like to have subtitles turned on using Cinema HD & Cyberflix. I’ve used the MX Player Pro version from Troy’s toolbox on the previous 2 versions of the ONN box, and on both, I can select the 3 dots in the upper right corner and select Settings to change some of the settings (I’ve been having problems decoding audio on some sources). However, with the ONN Pro box, I can’t select the 3 dots to change settings. Even using Mouse Toggle to try selecting the 3 dots doesn’t work. Any ideas on how to change the settings?
Secondly, when I use MX Player Pro to select online subtitles, I get a message stating “Can’t save files on your subtitle folder. Please check write permissions of /storage/emulated/0/Subtitles”. I’ve enabled all permissions for MX Player Pro, but no luck. Again, any ideas?
