Onn 4K pro create folder
I have Tivimate premium and using the Onn 4K pro. I want to make a backup of tivimate setup. Does anyone use the Onn 4K pro and if so is there a way to create a folder to save the backup to.
Just doing a brief search, There are several threads regarding how to do this, and I am attaching one of them. @Miki was the author
Using the X-plore file manager! Good luck
There is also an app in the playstore called File Manager + that works very well on the onn4k.
