One Click Kill Apps for Tablets & Phones
I use this app on my Android phone and tablet. It seems to work great and you can create your own exception list (white list). The app is free w/ads, but the ads are not too intrusive at all.
This app does what the TDUK app does for streaming devices. The Kill App app is NOT compatible with streaming devices.
Here is the link: KillApps - Close all apps - Apps on Google Play
heres the one i showed you a mnth or so ago, been using it for yrs, same app…
(worx on my droid boxes too)
Hibernator :
1 touch widget
Custom list Exeption list
Total system
https://www.google.com/url?sa=t&source=web&rct=j&url=https://play.google.com/store/apps/details%3Fid%3Dcom.tafayor.hibernator%26hl%3Den_US%26gl%3DUS%26referrer%3Dutm_source%253Dgoogle%2526utm_medium%253Dorganic%2526utm_term%253Dhibernator%2Bapp%26pcampaignid%3DAPPU_1_kNk5ZMCyKJKrwbkPwp68wA8&ved=2ahUKEwjAup7Au6r-AhWSVTABHUIPD_gQ5YQBegQICBAC&usg=AOvVaw2Vv82CpFIMUX5AHQDB5uH-
can also get it at apkpure & othr outlets …hth
They’re almost identical.
